When I first purchase the Arlo Pro 2 I was pleased with the quality of the video/pics. That said, after having this installed for over a month now I am really unhappy with it. I wanted to view something that happened in my front yard a few days earlier then when started to look for the playback. To my disappointment the recording lasted less than 10 seconds??? I have checked other cams (i have 5 of them) as well with the same result. I really dont know how to fix this even after reading all of the arlo community boards. I should be able to see continuous video for much longer periods but that does not seem to be the case. Please tell me there is a fix for this or did I waste over $600 on this seemingly useless system.
Have you checked the recording times set in the Mode ?
Thanks for the reply.... yes i show it on "record until activity stops(up to 300 sec).... is that the right setting?
Yes or u can pick below that for a set time. I forget what its up to but its good. I use both on different cameras. I have the pro3 so not sure if u have the set time.
