  • 1 Reply
  • 2310 Views
NickiMac
Was working but then the icon disapeared - as far as I can see I have the most up to date app ?  A friend of mine also noted her icon was missing..... there are no available upgrades available in the app store - can you tell me what the go is...I did see somewhere that with the last Apple update that this may have caused this issue?:
There was an update a short time ago and that version has been pulled and replaced...
Si if you delete the app and re-install it the mic issue should be solved
