Arlo Pro Plugged In - No Lights & Will Not Sync
camera stopped recording. its plugged in to try to re-snyc, base station seems fine but camera is not showing any light on it at all - its plugged it ( no battery)
Try and insert a battery in case there is a problem with the power supply. If you have another camera then try the power supply on that camera.
Thank you so much for input.! Unfortunately it did not solve the problem and it is broken after or year and a half. Disappointing
