Arlo Pro: Pan and Zoom setting results in black picture
So I'm thinking that this isn't a camera issue, but more than likely a camera positioning issue with reference to the base station. Just seeing if anyone else out there has experienced this.
On the camera I have facing my driveway (camera mounted on roof awning) I am trying to use the Pan and Zoom feature to narrow in on what the camera sees. When I do this however, all video recorded or viewed live is black. Can't see a thing, but audio is recorded.
When I revert back to the standard settings, the video is fine.
Again, this isn't a camera issue, as I have used other cameras (tested pan and zoom prior to moving) and when I put them in the driveway location (same symptoms)
Has anyone else experienced this? Thank You
This has been previously reported here and to support. It's a known issue but another open case wouldn't hurt.
I was on with support earlier so I believe I have an open ticket.
Do you know if there is a way to set a "boundary" for motion detection or is the only option to reduce the sensitivity?
