Arlo Pro Not Sending Notifications To Pixel 3
  • 6 Replies
  • 3710 Views
dl1
I had no issues receiving notifications from arlo on my previous Android phone.  I recently got the Pixel 3, got a few notifications from Arlo at first but after about a week I no longer get any notifications.  Notifications are definitely on, I checked in Arlo on the camerqa, in Arlo settings and in my phone's application settings.  My boyfriend has an old Pixel and has no problemns, gets notifications.  The arlo does record bc i can go into the library and view the recordings but I get no notification which is terribly frustrating because it is half the purpose of having the Arlo to begin with.
Help please!
6 REPLIES 6
Have you checked the app permissions in the phone settings?
dl1
I don't see anything in app permissions that would be relevant. Specifically what would you suggest?
Are all permissions allowed? Are notifications allowed for the app?  It may be useful to reinstall the app.
JoeCymru
Virtuoso
Virtuoso
Especially phone permission under permission settings for the Arlo app (settings>apps>arlo>permissions)
dl1
Thanks for the suggestion. Notifications are on and phone and microphone permissions are allowed and have been. The others aren't though, do they matter?
It seems to give me notifications for a day or two after I've opened the app but after that it stops until I open the app again. So if I don't open the app up for a week I'll get no notifications but when I go in I'll see the recordings from motion over the past week. And my boyfriend's phone gets notifications no problem. I guess I'll try reinstalling the app next. Any other thoughts?
JoeCymru
Virtuoso
Virtuoso
Those are the only permissions I give Arlo and I am having no issues with this. However, sometimes I will get notification delays when I am relying on 4G and I am moving through different environments. If you and your boyfriend are in the same environment and he is getting notifications and you are not, then check your sharing set up (depending on whose account it is). You may want to stop sharing on the account and then set it up again.
