Arlo Pro No Live View
Have you tried swapping the camera with one in another location (seeing if the problem moves with the camera, or stays with the location)?
If you have storage installed in the base - Have you looked there for recordings from this camera?
Thank you for the reply. Yes, I've moved it to multiple locations, including right next to the base station. I am ready to give up on this camera, but I will keep trying if there are other suggestions. I've spent hours and duplicated the steps I've always used to add a camera. My thinking is that somehow the camera information is cached in the base station, because the same thumbnail from weeks ago shows up each time I add the camera after removing it. I would like to avoid resetting the base station and needing to reconfigure the other six cameras again.
I note your familiar with arlo operation but I have in the past seen similar funny functionality issues as a result of rule settings being corrupted because they are set to non default values. I have since learnt to keep everything as default as possible to get away from these quirky issues.
@K22 wrote:
I’ve been working with Arlo cameras for years, and I know I’m not doing anything different than I’ve always done, so I am fully certain this is a hardware/firmware issue. It has nothing to do with the app, the website, or the network. Unfortunately, I haven’t had any time to look into this further because of work. The really frustrating part is that it was working normally, and even now it senses motion, turns on the light, and the system knows it’s there, it just will not show or record video.
It looks like you've done all the usual stuff (rebooted the camera by removing/replacing the battery, and restarting the base, removing the camera from the account and re-adding it). Livestreaming should of course work however the rules are set up.
I'm wondering if the camera has simply failed (something with the sensor or the image processing hardware, since that is the part that isn't functioning).
