Having an issue with Nightvision.
During the day, live view works just fine.
During the night, when using live view, it works fine..but after shutting down the live view - I get about 4 or 5 alerts in a row right after using live view that motion was detected (and it records for 20 seconds each -as I have it set to do)
Tested by turning Nightvision off, live view works, and when closed, no motion detected.
It seems like the camera is detecting its own Nightvision light as motion for some reason.. Bug? anyone else have this issue?
I have the latest base and camera firmware installed.
Thanks.
Hi,
I just purchased my arlo pro camera and am having this exact issue with night vision. I have the camera set up on my front porch underneath the awning facing my driveway and through the day it works great but at night it's a disaster. After I hit the live view I immediately get multiple notifications after with nothing on the camera. One morning I woke up with 46 notifications. It went off every three minutes until the camera finally died. The only thing that has helped is to turn the night vision off, turn my porch light on so I can still capture a picture on the camera and hope to catch the burglar that broke into my car. How do I know if I have th H7 or H8 version? Should I just open a case to try and get a new camera? I'm not really sure how to go about getting my camera fixed. I really like these cameras but want them to work how they should!
1. Return/exchange at the store you bought it at (Quickest).
2. JamesC just said they have identified the problem but haven't told us if the fix is fixable by a firmware upgrade, so you can wait and see what they say is the official fix.
3. Open a support case with headgear and push for a replacement but it takes a little bit and a lot of people say they make you pay for shipping it back.
I was notified via my open case file that the issue has been identified as a hardware problem and that my cameras will need replaced. I am sending (4) of my (7) back.
I am having the same problems with my add-on cam.
purchsed mine last week from Best Buy.
Should I just return and hope for one that works?
You would have to determine what is easiest for you. If you are close to where you purchased them it might be worth a try returning them and seeing if you get one that does not have the issue. In my case it is return via Amazon or Netgear. They must have a fix already on the HW issue as they gave me an RMA number to send (4) of mine back. Hopefully I do not send mine back and then wait weeks / months for replacements. Other than this issue related to false motion alerts, we really like these cameras.
Contact support through their website. it's actually pretty slick! They are fast to communicate back and forth with.
They will get you to do a bunch of troubleshooting things and once the determine they can't fix it....they will send you out an RMA. You have a few options. You can pay a little bit more and they will send you the replacement cameras out first....then you can send them your old ones. This is what I did....I didnt want to be without any cameras. I think it cost be about $22. Would have liked to have seen it free...but considering they ship them out first and then you ship back...not bad.
I have had zero issues so far wtih them and are working just like they are supposed to.
JamesC, do you have any new/more information to share on this issue?
I have a final follow up on my issue. The 2nd replacement camera Netgear sent, an H8, is functioning properly. I now have 3 of 3 working cameras. Yeah.
I would just consider yourself lucky InsaneDiego, and the problem could return because any units their sending out, there is no way their fixed, people are just getting a luck of the draw.
It's not yet dark so ill have to check the nicht 😉
I have 4 cameras with skins. They are not the problem. The hood does not reflect light. Mine work great and I highly recomend them.
My cameras did not have skins and they fired false recordings like a machine gun. Had 2 replaced which are now working. Bought a new single camera (H8) from Best Buy and it's doing the same but not as bad... It's really hit or miss, I'm returning the single as soon as I see new inventory on the shelf.
Be aware that the hardware version doesn't necessarily mean anything. I have H7 cameras that are fine and have been so since early on (I had them replaced and all have been H7).
I have had the false motion issue on both H7's and H8's. I currently have a case open with NetGear and they have given me an RMA to send (4) of my cameras back. They have told me that there is a hardware fix.
Almost at the same time I was asked to beta test a firmware update and see if that fixes the issue. It was installed a day or so ago and I have just started testing.
Keep in mind that my issues only occur when it is dark and nightvision is in use. If it is dark but my lights are on, I do not have an issue.
Last night after all of the lights were out, I tried multiple live views and created actual motion. None of the cameras with issues returned ANY false motion alerts. Previsoulsy they would 100% of the time.
Fingers crossed, going to test some more over the next few days.
All I can say is that they must be attempting to correct the issue with a Firmware update. Assuming it is successful I would guess that it will be rolled out across the board to all users. If not successful, may make another attempt or go the hardware route.
If you have the time to wait, I will update frequently on how the firmware testing is going. Ultimately it will be a NetGear decision if it appears to work and when it would be made widely available.
