Audio alerts going off all the time with mic sensitivity at its lowest setting 1 just because its a windy day 25mph!
Some mics can be more sensitive than others....
Only option is to dupe another set of custom modes for the ones you use with the sound toggled off called "windy days "
Ok will do!.......just another thing of note, the email responce notification to your reply on here, never came through to me as it has an "SPF Fail" marker!
