Hey everyone and thanks for your support. I have the Arlo Pro system. Its been great for the last 1-2 years. However, since the last firmware update I've had major lag issues with the live video. When selecting a live feed, the white circle appears as normal. After a couple of seconds, audio from the feed starts and the white circle changes to a grey circle. This grey circle continues to spin as the live audio is running in the background but no video appears. This will stay for several seconds, even minutes. Eventually the video will appear or i'll get a failed to connect message. I then have to restart the app and it normally works.
My remedies included restarting the base station, updating firmware, restarting cameras, disconnecting power cords, updating firmware on my Nighthawk router, restarting the router/network. None have worked. Seems like most of you complained about similar lag issues back around May but I haven't seen any updates since. Have you all figured out a fix? If so please share. Thanks again!
Hi maverick17036,
What device are you using when you run in to this issue? Do you see a difference if you use a different source for the Live view?
Have you had the same issue with the Web Portal. Can you test it with Google Chrome?
It works via Chrome and Safari just fine with no issues. I don't get any "circle" when uploading the live feed. It just says "please wait" and then the live feed appears. The circles only occur on the app. I think there is a flaw in the app. Its not my phone as the same issue happens on multiple devices. Its not my network as the live feed loads fine on other browsers on the same network. I've tried deleting the app and reinstalling it but the same issue occurs. This is very annoying and troublesome to the point that I'm thinking about selling my system and going with another company.
Good Morning maverick17036,
Is this issue related to a single camera, or does this behavior happen with all of them?
I am having the same problem.
Hi myhomie02,
Have you had the same issue with the Web Portal. Can you test it with Google Chrome? Is this issue related to a single camera, or does this behavior happen with all of them?
