Arlo Pro I need to extend the motion range another 20 feet.
  • 1 Reply
  • 3162 Views
Hondo49
My cameras work great, Im trying to fine tune them, I need to extend the motion range another 20 feet.
I had a little brain fade, and can't figure it out, can use a little help, thanks in advance
That's not likely possible for people. 20 to 25 feet is realistically all you'll get. You could use a second camera in a location that would gain you that distance and create a custom mode that uses one camera to trigger the other using nested rules.
A detects, A records
A detects, B records
B detects, A records
B detects, B records
