Arlo Pro I need to be able to record 24/7 without motion on
I need to be able to record 24/7 without motion on. max about 1 week. Looking at most cloud packages this doesn't look possible. Am I wrong? Do I STILL NEED A WIRED SYSTEM?
Id really like to not spen thousands of dollars.
thanks
Unfortunately, I think you are correct and will need to get a wired system with local storage to meet your needs
The Arlo cameras are NOT 24/7 record cameras... they are a type of "detect motion - then record "
They can be ARMED to detected motion for 24/7 but unless there is motion detected , no recordings will happen.
You could use an Arlo Q camera with CVR. The stream won't be directly downloadable but you'd have your 24/7 video to replay.
