Arlo Pro How To Turn Alarm On?
I just installed... Can use voice command but can't figure out how to use alarm sound. Also, can the alarm sent to your IPhone be louder ? Thanks
Sunapee,
Do you need help locating the button to "alarm" the the base station or to set the alarm as a rule? To sound the alarm, there is a drop down tab at the top of the menu that has the alarm listed.
Can barely hear the alert....wouldn’t wake me at night.
thanks!
Sunapee,
Have you tried adjusting the media/notification audio with your device?
