Arlo Pro Geofencing
  • 1 Reply
  • 1252 Views
adarshpatel
I have just installed an Arlo Pro and followed the prompts on the App (Iphone 6) to setup Geofencing. On clicking 'finish' on the final screen the mode briefly switches to Geofencing and then immediately thereafter in coupel of seconds switches to either 'armed or 'disarmed' depending on if I am home or not. I have deleted and reload the app and also restarted the base station to no avail. Please help.
GPS must be running so make sure a battery saving feature isn't turning it off...
Also some GPSs use AGPS which can be less accurate so try and increase the radius around you home location ( in settings )
