Arlo Pro Fixed Length Recording Ends Early
- 2
In my armed mode rules in the iOS app v2.5.1, I have each of my four cameras configured to record upon motion detection for a fixed length of 120 seconds. Each camera's rule is also configured to record on the other three cameras for the same fixed length. The actual recording lengths are much shorter than 120 seconds and vary seemingly at random. Also the recording lengths differ between the four cameras for the same recording event. For example, one camera might record for about 60 seconds while another ends after about 30 seconds. Does anyone know how to make the fixed length setting work properly?
Hi Rico----,
Have you power cycled your base Station?
What firmware version is your base station & cameras running? Have you updated to the latest Arlo Mobile App and tested again?
An October update of the app means it's out of date. However, I don't think that's the problem.
WHat's your upload speed as measured by speedtest.net? I suspect having multiple cameras streaming at once is swamping your upload bandwidth, causing the videos to not be complete.
Did anybody find a fix?
- 2
