Arlo Pro Firmware Won't Update
  • 4 Replies
  • 2070 Views
  • 5 In Conversation
RobBreak
On the main devices tab in the app over each screen it says that a firmware update is required tap to update but it will not update.
Anyone have this issue?
Try rebooting the base. That usually helps.
tracedog79
@jguerdat I am having the same issue.   Was hoping to come on here and get an answer but I guess not.  I've tried rebooting my base station but that doesnt seem to fix it.
Missy11
Same thing here.  A friend who is an IT guy tried to install it and same happened.  It may have been in the warehouse too long and the DVR is not updating.
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
