App indicated that needed to upgrade firmware. When I hit update and accept "are you sure" prompt, a spinner comes up and within minute, Error Code 4206 "Firmware could not be updated. Please try again later. (Error Code: 4206) comes up.
This is annoying as I can't get real time views from the camers, although they seem to trigger and send video clips to the library as per normal.
Anyone else?
Solutions?
Out of things to try...
C
Remove and reinsert the battery to reset the camera. You may also want to try rebooting the base.
