Every week or so one camera goes offline. It is wired for power because the battery doesn't last long enough, so I disconnect the power cable, pull the battery, re-insert the battery and plug it back in and I'm good for another week, but is quite annoying to have to do that pretty much every week. Any ideas why?
armbw,
When did this issue start with the camera? Have you tried to reboot the base station & test again?
