Is there a way to turn continuous recording on? Basically I want the camera to record more than just motion detections
Only way is if its a manually started record and even then it will shut down at the 30 min mark .
If you want 24/7 record, the only camera would be the Q camera with the CVR option ( indoor rated only )
