Does Arlo Pro supports continuous recording(CVR)? Thanks.
herbertjames12,
TomMac is correct, due to the battery operated design of the Arlo Pro, CVR is not a supported feature. The CVR functionality is available on the Arlo Q and the Arlo Q Plus, take a look here: What is continuous video recording (CVR) and how do I get it?
I would think prob not.... as the primary unit is battery powered ( even tho you can leave it plugged in to ac power )
herbertjames12,
You can record live video on the Arlo Pro. Not sure what the time limitation is (I tried 11 minutes). It appears to work with the power adapter connected, so battery life may not be a problem.
