Arlo Pro Cloud Storage Command Line Download Or API
Is there a way to programmatically download video from Arlo Pro cloud storage, using command line or some other kind of API? We are trying to find a systematic alternative to manually downloading video from cloud storage. Thanks!
Natively, no. But I'm pretty sure I read in here that someone was doing that and I thought they did it with IFTTT. (not positive though)
I have a Python script that I use daily to download all videos. It's not via any API (there is none) but just through commands that duplicate what the app or browser uses. I didn't write it but can send it to you if you'll PM me your email address.
Would you be able to share that with me please?
I have tried to send you a DM but I think you have them disabled.
Is the script able to run on a Raspberry Pi with Raspbian?
Cheers
Craig
