Arlo Pro Charging Question
  • 1 Reply
  • 3593 Views
  • 2 Likes
daveyir22
Hello - Do you need a charging station to charge the batteries for the Arlo pro or does the camera charger charge the battery when plugged in? We purchased 2 camera's and one of them after a short period of use had a dead battery. Charged the camera (with the battery in it) overnight and that didn't work so I'm assuming we need a charging station. Only issue with that is you can't find one to purchase online. Any advice would be greatly appreciated.
No, the battery pack can be charged inside the PRO and does not need the external charger.
Just plug in the adapter and it will charge... if it appears not to be charging, pull the pack and re-insert.
Check the SETTINGS on the camera and it ( on the page ) will show if in a charging state.
If still having trouble, contact Netgear Support
