Arlo Pro - Can multiple cams trigger a rule?
  • 1 Reply
  • 1155 Views
bengrilley
I set a mode for 2 of my 5 cameras to record motion during the day. I can only seem to set it to be triggered by motion on one camera or the other. Is there a way to record on both cams if motion is triggered by either cam?
You need to setup some custom Modes....
In them you can add multi rules, exp;
cameras A,B
A detects, B records
A detects, A records
B detects, A records
B detects, B records
It use to work quite well, now it should should work, but some have stated it is not 100%.
Try it and see
