Arlo Pro Cameras Speaker Has Low Volume
I bought these cameras to be able to speak through them and have people or dogs easily hear. We can't barely hear the voice through the cameras. I have the most recent firmware and it's still so low. How can I increase the cameras speaker volume?! Or should I return them?
We purchased our second arlo system, to add more cameras w/out using a cloud fee. Anyway, the first system had no speaker, this one does, and on our S6 we use for satalite tracking and our brand new s9's, the audio is barely hearable (is that a word?) , anyway, im now concerned over the lack of customer support I see here, and i know that ARLO has changed hands. I hope a fix is posted soon as I want / need the speaker function and no fix here would require me to purchase someone elses system.
Fingers crossed. Doug
There is no fix for it. Was same for when I purchased mine. They even replaced it. Its a design flaw and seems to be ignored. I went with Ring but to be honest even Ring has low speaker volume but its a lot better then arlo. Check to see if your phone has a mic gain in the settings. Arlo isnt going to fix it.
I'm looking around and noticed that my pro has very low volume. Looking for a fix. My app and cameras has the latest updates
Yes, live stream push to talk
Most people have their volume turned way up. You may want to try it yourself! Guru Made an excellent suggestion that works very well. If you plug-in an auxiliary mic to your phone like ear buds and speak through the mic it works great! Maybe you can suggest this to the rest of the customers.
Someone suggested plugging in an auxiliary mic, like your ear phones/buds. I tried it and it works so much better. the speakers are much louder. The problem is within the phones.
Try it your self and would love to hear a response?
