Arlo Pro Camera will not activate on motion as it has. Battery Holding full charge. Mic works
Arlo Pro Camera holding full charge. Not activating when motion present, but Mic works fine. I tried to re-sinc -- nothing changed.
Please help!
What is the modification?
WHat mode are you using? Is the motion icon for each camera in the Devices tab black or gray?
All 4 of my cameras are set on ACTIVE mode, the other settings are grey. Here is the latest:
I have 4 camers all are in the "Armed" mode. I think I just solved the problem (camera OFF) by opening the battery door, removing the battery for about 5 seconds, reinstalling it and turning the camera ON. It seems to be activating on motion now. Thanks for the reply
Hi jquerdat, I have 4 camers all are in the "Armed" mode. I think I just solved the problem (camera OFF) by opening the battery door, removing the battery for about 5 seconds, reinstalling it and turning the camera ON. It seems to be activating on motion now. Thanks for the reply
Yup, keep that solution in mind for the future. Computer equipment of all kinds sometimes need a kick in the arse to work. Resetting the camera that way and rebooting the base are always first troubleshooting steps.
