  • 1 Reply
  • 3026 Views
scbatech
I have two Arlo Pro Camera's that constantly go off at night when they is no motion .During the day they work fine it is just at
night with the night vision how can i fix this problem. I have to change from motion to sound so i do not drain my battery's.
There can be issues with certain cameras detecting motion and then repeatedly recording several more times afterwards, usually only at night - is that what you're seeing?  I had my cameras replaced but a firmware fix may be coming in the future.  Open a case with support for more help.
