Arlo Pro Camera-one camera that goes offline a lot
I have one camera that goes offline a lot, what can I do to correct?
Check the signal level at the cameras location, make sure it's not effected by other interference ( other wifi, microwave ovens , etc ).
If signal level is low, move the base closer by either ethernet cable or a wifi extender ( with an ehterent port )
Last, swap the 'troubled' camera with another working to make sure its the cameras issue ( see if problem follows )
