Arlo Pro Camera not recording
@KarsonK2 wrote:
I updated my Arlo app and now my camera will not record
Others have reported that these steps resolve it:
- remove base and cameras from the account
- reset the base with a paper clip
- add everything back to your account.
But the mods have also been able to resolve this remotely for some folks, so I am tagging @BrookeN , @JamesC , and @ShayneS to alert them to your problem.
I am having the same issues. The last recording in my Library is from June 13, 2024 at 9:37PM local time. After that, no recordings have been initiated/saved. I have recharged all batteries, reset the base station and cameras. I usually have dozens of recordings each day, but none for the last 36+ hours. I verified that my cameras do work, as I am able to view live feeds.
Just to be clear since too many folks think rebooting or power cycling the base is a "reset" (it's not), did you actually reset by removing the base and cameras from your account and set the system back up as new? Using the base reset button for >10 seconds until the LEDs flash amber may also be needed after removing all devices.
I suggest using a paper-clip to reset the base. It doesn't take long, and insures you are really starting fresh.
