  • 6 Replies
  • 3409 Views
dobbsy
Hi everyone.
The last couple of days one of my arlo camera is showing as offline, it’s powered via usb and has power to it.
I removed it via the app and re-paired earlier today and was showing as working again but I’ve just check and it’s offline again.
Is there a factory reset I can perform or should I order a new camera ?
6 REPLIES 6
How far is it from the base station?
Does it come back on line if you restart the base station?
dobbsy
Thanks for the reply,
No won’t come back on after restarting the cameras and base station. It’s been ok for about a year and all of a sudden started playing up.
The base station is about 18 meters away on the same floor
Can you move it closer (as a test) and see if it's a range problem?
dobbsy
Will give it go tomorrow night, just strange it’s suddenly stopped again, is there a factory reset option on the arlo pro cameras ?
szabi510
Hi,
did you solve it?
dobbsy
Hi
All sorted now, I move the base station and no change, I removed the camera and re-assigned it worked for about 5 minutes then stopped again. So swapped it with another camera and now use the flaky one in my garage powered via battery rather than USB,
Thanks Guys
