Got a new Arlo Pro Camera. I would like to mount it inside a room but the perfect angle that works for me is at the corner of the room. Seems like the magnetic mount cannot be mounted at the corner of the room.
Any suggestions/ideas on how I can mount the camera at the corner of the room?
Thanks.
A ceiling mount in the corner would work well and allow you to angle the camera in most required directions
Try to imagine this VMA1100 in the corner of the ceiling
