Hello, my Arlo Pro camera battery discharged fully. I recharged the battery, and since recharging I receive contant messages that audio has been detected by this specific device. The audio is deactivated in the settings, but the messages continue. In the 'Devices' tab in the App, the speaker is not greyed out although the audio is deactivated in the device settings. It is really very irritating as these messages are appearing every few minutes. Any ideas?
Ed
Check your Mode Rules. Detects Audio probably got checked. Uncheck it and make sure to save the Rule and Mode.
Thanks. This was the solution. I’m just surprise that the device settings indicates that audio is off. Seems a little illogical. But when you know then...
