Arlo Pro Battery Is Draining
Since the last update that was problematic to install my cameras are losing battery fast. I am having to swap batteries almost every week now. Will there be another update to fix this issue?
The battery drain issue should be fixed. Verify that you have the latest firmware. Power cycle the base to see if that helps.
