Which is the single battery average duration (months/days... regular use) about new Arlo Pro camera (starting from a charge 100%)?
Thanks!
The batteries in your Arlo Pro Wire-Free or Arlo Wire-Free camera last for about four to six months with normal usage, which is about five minutes of recordings a day. For more information on Arlo Pro rechargeable batteries, see here: How can I extend my Arlo Wire-Free or Arlo Pro Wire-Free camera’s battery life?
Additional rechargeable batteries will also be made available for purchase: Arlo Pro Rechargeable Battery (VMA4400)
It's new so unknown. I haven't looked at all the details/manuals yet but that would be a good place to start.
In the data sheet the battery capacity is 2440mAh, so maybe 70% more capacity compared to the ~1500mAh batteries in the original Arlo. Of course, if the Arlo batteries are wired in parallel, as been reported, then it's less than the 3000mAh of a parallel wired setup.
Jeff.... I zoomed in on the picture and yes, its 2440mahr, but also a 7.4v pack.... so I think in the long run it will last about the same as the OEM
what is the battery duration (starting from a charge 100%) with 24 hours recording..
regards
You can't get 24 hour recording with either wireless camera. I can say that my Pro cameras are still showing 100% after 2.5 days of operation with several minutes' worth of recording each day (testing, etc.) I can't tell you the exact amount of videos/live view without a lot of investigation. I'd kinda estimate 10 minutes a day so far but that's +/-.
I am having mixed experience with my Arlo Pro battery life/duration. For instance, the following is applicable since installing them on October 22, 2016 which would be about one week now.
Cam 1 - 58%
Cam 2 - 93%
Cam 3 - 100%
Cam 4 - 100%
Both Cam 1 & 2 are within the standard motion detection and 5 mins per day recording band. However, I do believe that Cam 1 battery might be defective and as such opened a case with Arlo support. I was told by the agent that they don't have any RMA battery to replace mine. Therefore, the recommendation is that I can return the product to the store that I got it. Alternatively, I could check back within one week's time to see if they have any battery to replace the current one. I spent about one hour with an agent doing all the standard troubleshooting activities before an agreement that something might be wrong. An example, they asked me to swap Cam 2 battery with Cam 1. They asked me to resync the camera, reboot the base station. You name it, I've done it in an effort to find the problem.
In addition, they told me that on their system it is showing that my battery is showing full (100%) even though on the actual app both Android, and Windows showing Cam 1 and Cam 2 at these battery level. Therefore, I am now totally confused as to what is really going on.
Bob_1963,
Battery life could be affected by poor WiFi signal strength as well as camera usage. What is the WiFi signal strength icon showing for your cameras? How much usage (live streaming and recording) did your cameras see in that week?
Zandex,
I'd like to take a closer look at your support case. If you could, please provide the case number that you have open with the support team.
I reiterate that Netgear SHOULD offer a DEAL TO EXISTING USERS for the Arlo Pro...
it should be thought of as mutually beneficial to your earlier adopters and Netgear, we (the users) would get closer to the features and benefits we believed we were originally purchasing (& of course a bit more) and you (Netgear) would get $$ and happier user base..for obvious reasons.
Right now with the release of the PRO and its pricing "it appears" that you just do not care about the existing users...
