Arlo Pro Basestation keeps going offline
Hi everyone. My Arlo pro basestation keeps going offline - around once a week. It will reconnect with a restart, but then I need to add the cameras again, which essentially makes it useless for going away. All the lights stay green as normal. Is anyone else experiencing this ?
If all LEDs are green, the system is working and it's likely a display problem. Try logging out and back in, force close the app as well as try a computer web browser when this happens.
