1. Does Netgear sell the Arlo Pro Base Station Separately?
2. Can you set the Arlo Pro Base Station Siren to be triggered by individual cameras?
Thank you.
1) Eventually.
2) Yes, in each rule for a Pro camera.
How is 'eventually' a solution??
There's two parts to the original post. Both answers are correct. I suspect the "solved" is relative to the second answer.
