Opened 2 tickets - Agent at Netgear told me I would need ports open [80, 123 & 443]. Called my internet provider, verified the ports are open - suggested I get new router from them [changed out old XyZel router for new Comtrend router), Verified with provider ports are open. Plugged all up as directed by Netgear/Arlo. Still amber light on base for internet. Went to bed. Still the same next morning. Told to return product to Best Buy and get another one - the base is defective. Drove 60 miles - exchanged product. Hooked it up and still get amber light on base for internet. Best Buy suggested we contact Geek Squad - did that - agent suggested we have someone come to our home - a charge of $99.00! What is the deal? Can't anyone help me? This system sound great on paper and exactly what we need but I cannot even connect this VERY EXPENSIVE paperweight. Please - I need a real solution to this issue, I am not a geek - I am an average person.
Teresia,
I've reviewed your case notes which indicate the issue has been resolved but do not say how. What was the issue you were experiencing?
Sorry for the issues but I don't see how it's a Netgear problem. You swapped routers twice which also changed the ports you used. Swapping ports being the fix seems to imply that something else was the problem such as improperly connecting the cable on one or both ends or the cable having an issue. I don't mean to insult your intelligence or efforts but your solution seems a bit of a stretch. Maybe I'm missing something.
