Arlo Pro Base Station Goes Offline, but all lights on the base are green
Just bought the Arlo Pro 4 Unit System VMS4430 in mid August. Setup was a breeze. About a week later while I was out of town the unit went offline. Being out of town when I needed it most it going offline was rather inconvenient. I got home last night and saw that the internet LED was Amber. I rebooted it and all came back all green with internet light blinking with some activity. Unfortunately the app and web browser still showed the unit offline. I finally removed all the cameras and base station in my profile, perfromed a reset and synced all the cameras back to get it to work.
I know this seems to be a common issue reading the forums, but is this a common fix? If this is the case then back to the store it goes. The convenience of having batteries with solar panels is great, but if the system is unrelable then it is not worth it. The video quality IMO is not very good compared to the 1080 system I have in our business that cost 1/2 the price.
Version 2.4.3.821_17721 Released 08.08.17
You posted the app version. You need to check the individual devices in Settings, My Devices and compare to what's listed in the Release Notes section here.
That said, it's not unheard of for this to happen but is usually related to power and/or Internet outages. You can't do anything about Internet outages short of having a router that support a 4G fallover configured but power outages can be easily managed with a UPS for your modem, router and base.
Base Station HW Version VMB4000r3 Firmware 1.8.10.1_13433
Camera HW Version H8 Firmware 1.092.0.4_13099
Per my previous response, if having to reset and resync each time, that would not be a good solution and the system is proved to be unreliable. Does anyone have any input?
*bump
With all the issues with the unit losing connectivity, am I the only one experiencing this behaviour?
I just had an issue with devices being reported offline. I logged out and back in and all was fine.
