Arlo Pro Audio Alerts When Sound off In Settings
I have audio turned off in settings yet I’m getting Audio alerts. Anyone else experiencing this? It’s annoying and running down the battery.
Have you turned off the mic for all cameras ? It's a per camera issue if more than one is still set for audio
If it is only one, then I might try to use Remove Device for that camera, pull battery and reinstall, then bring back as if new... This will reset all for that camera to default settings and eliminate possible glitches in the settings.
Hi. I’m having a similar issue. Did you resolve this problem? How? Thank You.
I have turned off microphone and I still get annoying audio alerts.
Turn off the audio detection in your modes and rules.
Thanks. I l realized that under modes I had set up 3 different custom time modes...day, evening, and night. In each there are different cameras. Though I’ve turned off audio on each device setting, under each customer time mode I had not. It seems to have solved the problem. Your direction got me re exploring my setting under modes. Hopefully others will find it useful to avoid hundreds of audio triggered videos and notifications by reviewing also any custom time modes that you might have created.
And Happy Holidays!
