Arlo Pro / App
Hi, I habe 5 Arlo Pros running and everytime I want to set the sensitivity or test the sensitivity, the App closes. Same thing with Kamera positioning. Any Ideas? The Cam alerts me everytime a bush moves....Using an S7 Edge with Android 7. Thanks!
Problem has been solved, thx
Have no problem with S7 and Marshmallow , but Nougat is brand new and don't think many have it yet
Might be nice to share what the issue/resolution was in case someone searches the forum with a similar issue.
I ditched Arlo! As a Company they hold their Customers/Us in complete contempt! We beta test producs for them, the products only work properly for ~70% of the time at best!
If you are serious about your home or work security then look elsewhere! Get a ip Camera System with an NVR and some Blink XT cameras to cover the places you cannot run a cable to. You will NEVER regret moving away from Arlo!
