Arlo Pro Activity log
  • 2 Replies
  • 4063 Views
nxp16
Is there an activity log function that shows when each camera was disabled and/or enabled? ie to demonstrate that cameras were actually set on to motion detection and any breaks in surveillance are due to no motion not no power?
Not on the user side.... not sure what logs they can check on the server side ( tho they can see if base is up or not )
pc2k17
Hero
Hero
If you plan on going further with home automation, beyond cameras, and you like lots of logging, get Samsung SmartThings. The logging in the smartthings app is robust to say the least and sometimes way overkill. It will log your arlo cameras.
