I have just installed a new satellite internet system called Starlink.
Can I connect my Arlo camera to this system?
if so how?
Can I connect my Arlo camera to this system?if so how?
Are you using a base station? Or is the camera directly connected to home wifi?
If it is connected to home wifi, the simplest path is to set up the Starlink WiFi to use the same network name and password as your old router. Also make sure the wifi security is WPA2 (AES).
