Arlo Pro 3, Arlo essential video doorbell wireless.
I was reading how to get alerts on the video doorbell and it sounds like I can by clicking modes in the app, and then clicking device (and that’s where I’m stuck b/c ONLY the base station shows up. I understood from the documentation, that I should see all my cameras there, be able to select the one I want and then set up specifics for that camera..,lease set me straight. I just want to get motion detection from the video doorbell and I can’t. I already get it on my other three cameras
Is the doorbell connected to the base?
If so, you select the base. If you edit the mode for the base, you will find rules for cameras (including the doorbell). The rules are where the notifications are enabled. (Note if there is no rule for the doorbell, then it is disarmed - so you'd need to add a rule).
