Arlo Pro - 2-way Audio Problems
I've read a few early reviews that the 2-way audio on the new Arlo Pro isnt very good. (The complaints are that its difficult to hear the person whether you're at the door or listening from your iPhone/Android remotely.
Is it possible for this issue to be fixed via firmware or is there no way to improve the 2 way audio functionalty?
Thanks,
D.
Right now it can only be fixed in the app. My volume using a PC with the mic gain turned up is good. No way to do it on my Android devices.
Fixed in the app.. do you mean an update to the app itself as well as a firmware update?
There has been an upgrade on the Android app which had the lowest volume outputed at the camera.
It can still be improved.
Good news for the Android app... Hoping that update for the IOS app will happen as well.
