The USB recording option is a great feature, thanks for that! But, will the system continue to detect and record on USB if you have an internet outage?
yes... if internet goes down, it continues to record to the usb device
Yes it wil, that is the main idea behind recording locally ![]()
I ditched Arlo! As a Company they hold their Customers/Us in complete contempt! We beta test producs for them, the products only work properly for ~70% of the time at best!
If you are serious about your home or work security then look elsewhere! Get a ip Camera System with an NVR and some Blink XT cameras to cover the places you cannot run a cable to. You will NEVER regret moving away from Arlo!
Thanks TomMarc and MarkC, much appreciated!
