Good Morning
Today, when I left, I noticed I didn't get an alert from my driveway camera. When I got to the office, I logged in via the web, and noticed that under my "mode" tab all I see active is a little clock. Normally, I keep my arlo in a "scheduled" mode as I have different cameras I arm/disarm and sensitivities that I adjust during different times of day. What I should see is the little clock next to the word "weekday" as that schedule should be active. However, all I see is the clock which is odd. I went to the devices page and noticed that the "motion man" was not lit on any camera that should be armed. I forced the mode to armed and the system armed as normal. When I go back to click "schedule", again, all I see is the clock but no mode it's running and the "motion man" is not active on any camera. Strangely, when I go to the app, and force schedule mode, it appears to show the clock - weekday and the "motion man" is lit within the app on my phone. This does not match what I see when I logon to the arlo website and my cameras are not recording in the scheduled mode even tho they should be. I double checked the schedule, all looks fine. I've made no changes to these settings in over 6 months. I've already rebooted the base but I'm still seeing the same symptom. TO me, it appears that the "schedule" mode is not working as it should at this time. Anyone else seeing this?
This morning, although still recording thankfully, my custom modes are not what i made, they've been renamed, and reset as in the modes i thought were running on the schedule were no longer existing. And these new modes had no rules set up, just empty blank custom modes.
ALSO and this is important if you didn't notice, the PRESET Armed that comes automatically with the modes, is screwed up completely now.. un-useable.
It was using 1 camera to trigger ALL cameras to record, so everytime a car drove by outside, the outside camera would sense motion, start recording like expected, but also every other camera with that time stamp. Try as i may i cannot add more rules to that preset, i can't select a different camera even. All i could do was remove all the conditions in that preset and not use it.
After more troubleshooting, and no reset this time as i was away from the house, i logged into the website, basically removed all settings from the broken Armed preset that arlo has& created my own custom mode for armed, recreated the new schedule as per the new custom modes, again, and fingers crossed bugs/hiccups are no more, still testing this though, as I'm not convinced the geo fencing/schedule is cooperating but I'll wait& see.
So, hard reset may not be the cure all we are hoping for, mine still has a mind of its own apparently...
☝ but everyone having this issue should also look into that Armed preset, as mine had been changed to a point it no longer functioned as expected.
Well, since yesterday when I noticed the modes acting up again, the modes themselves are cooperating as expected, but the geo-fencing, or maybe the schedule portion, not sure, is still not working properly. Seems like it's not recognizing when the time on the schedule is set to change modes. Manually changing the modes in the morning is my only fix at this moment, I may do another hard reset, but still hoping I can. I've troubleshooted a bit, if I tried geo fencing with 2 custom modes, neither being the schedule choice, then it seems to work. - Maybe just an issue with the schedule? Are we ALL using a type of schedule/ geofencing choice? just curious
So I deleted one of my custom modes and it deleted ALL of them! Additionally the stock ARMED mode has NO editing options anymore! WTH IS GOING ON???
Try using a computer browser until the issues with the app are solved.
That WAS on a computer browser. I used EDGE and CHROME and there is NO Rule editing options at all! In fact the ARMED mode is identical now with DISARMED mode. ARMED mode has NO editing options! I had to create a CUSTOM mode that mimicks the ARMED mode for it to work at ALL! When is Netgear gonna replace the imbeciles that code this crap??
I set everything from scratch. Deleted all cameras and the base station first. The rule options for the stock Armed Mode returned and so far everything is working as tested. We will see if it still works after the clock strikes midnight. If not, this junk is gonna learn how to fly and I will buy me something that actually works.
I’ve managed to do a quick fix on mine by adjusting shedule by removing times slots between 12:00 - 12:01 and starting from 12:02.
The fact still remains I have a gap in security for something that I spent almost £900 is just unacceptable and no communication via email for such a widespread issue, not all customers use the forum all the time!!!
Yes, there seems to be a problem to "switch" from ARMED to ARMED at 12:00AM. I had no recordings last night again. I set up a custom mode that mimicks the stock ARMED mode and let Schedule switch to that at 12:00AM and see if that works. If not, I'm getting rid of it. I am sick of it!
To my knowledge I've seen no mention on this "issue" under they're announcements or anywhere else i can see in the support site. If anyone comes across a mention, link it to this thread pls?
Try setting the schedue from 12:00AM to something and then another from another time to 11:59PM. I've noticed that the current scheme wants to use 12:00AM for both settings unlike previous iterations.
"This type of case seems to be a growing trend. We have already notified our development team and are working with them to isolate the root cause of the issue. I just wanted to let you know that we are still investigating the case. We do not have a solution yet. We will email you as soon as we have the fix. Apologies for the inconvenience."
I guess patience is our next step.
@JamesC or @DawnM Do we have an update on the schedule issue? Mine seems to work fine during the day but once i get to midnight it disarms and doesn't follow the schedule. The app is also still not showing it properly, but the web site shows it correct. I'm having to manually arm it at night to ensure it stays that way. I prefer to have the schedule manage the modes as I use different sensitivies and settings at different times of day.
yep, same here, except the app on my phone show disarmed when I click on the Schedule mode. And I get no notificiations either, which seems to be happening since the last update to the ARLO app. If I go online to the website, and go to my schedule mode everything looks fine (and armed) during the current schedule settings. The app on my phone just says disarmed... something isn't working right with the app.
I just looked at the Apple App Store and don't see Arlo 2.5.1 posted yet. Schedule mode is not working anymore on my system (looks fine - shows clock and description when you set it) but if you then close the app by finger scrolling it up and go back in it shows motion icons gray when looking at Devices). Not getting text alerts either. I tried setting Schedule to start at 12:02 AM and end at 11:59 PM. Phone app still grays out motion icon after closing and reopening the app. Then when signing into the Edge browser it shows the motion icon black so the phone app is not agreeing with browser.
I have the same problem. Here's what I did to fool the schedule: Create a new Custom Mode with the same rules as your stock ARMED mode. I called mine ARMED NIGHT. Run the stock ARMED mode until 12:00AM. Then run the Custom ARMED mode from 12:00AM until you want to switch to a different mode again. Worked just fine last night.
I experienced a similar issue: https://community.netgear.com/t5/Arlo-Pro/Schedule-always-skips-Monday-since-2-5-0-update/m-p/157618...
One workaround I found seems to be: as long as I avoid whole hours around midnight (always do 11:59PM or 12:01AM), and delete/re-add your schedule, it seems to work -- at least displays correctly inside app, though I need to see if the cmaeras are actually armed according to schedule. Will keep an eye on it in a few days.
I have a custom mode of front door armed only. My schedule has that mode plus the armed built in mode that arms all cameras. I deleted my whole schedule and set it up as you did starting at 12:01 AM and ending at 11:59 PM. When I select schedule and then hit the back arrow, it shows a clock and to the right of that the correct mode for that time period. Looking at the devices screen, the motion icon is dark (correct action). All good until you exit the app, go back in and notice the motion icons are all gray in devices. Therefore, your suggestion completely failed for me. Are you completely existing the phone app and coming back in to see if icon is dark? The only way this app version is working for me is to not use Schedule and select either armed mode or my custom one camera armed mode. The cameras then record correctly and send me text messages. Sucks to have to manually select modes though instead of schedule. Arlo, fix this soon!!!
Sorry it seems to not work for you. After all it's a work around for a bug...
For me, I tried to completely kill app (on iOS that means double-home + swipe up), and launch it again, in schedule screen, eveyrhting is still there. Though now with your info, I need to see if it actually works according to schedule. I think I need to wait until later when I go home (I'm in office now and the geofence mode switched it to arm).
