Arlo Notification LED Light Is Not Working/Blinking
Galaxy S7 oreo 8.0 The notification sound is now stuck on the same sound as my text messages. Even after I've changed it in the settings. Also, my cells LED doesn't blink anymore with notifications. I've changed the color and blink speed options, but still nothing. I just barely fixed the multiple notification problem. C'mon arlo, please fix this issue. Thanks.
After the last couple of updates when the people working for Arlo broke everything, then try to fix it. The notification light doesn't blink anymore when my camera is triggered. If anybody has a solution appreciate it if you let me know. I'm using a Samsung S8 Plus
One other thing not sure if other people are having this problem. When I close the app I'm getting notification sound when there is been no triggers of my cameras.
What version of the Arlo Mobile App are you using? What Android version is your Galaxy s8 running?
The custom notification issue is being investigated & we will report with an update as soon as possible.
Regarding your second issue, What version of the Arlo Mobile App are you running?
You have tried to remove & re-install the App already?
Anyone on android......... you have the ability to unistall the new app and go back to an older working version of the app. Bing or google how to install older versions of app on android.
I'm still on an older vewrsion, knew better not to update until the bugs are worked out, and everything is working fine. I have blinking led, my own custom notification sound, all icons, easy view of camera with one swipe, etc, etc....
Notifications in the Arlo app are broken. For sound changes on Android with 8.0, you may now be able to change sounds by going through the phone: Settings>Apps>Arlo>Notifications>Notifications>Sound. This appeared on my phone when the Arlo app updated. However I have not found any way to change the notification LED color. thatexists only in the Arlo app and does not work.
