Arlo Legacy app works well but says no longer supported. Trying to install new app but won't sync.
The Arlo Legacy App worked very well but you kept saying that you no longer supported it. I am attempting to install the new app and it won’t sync with my phone. What do I do?
Have you removed the old app? Reboot the phone and reinstall the app. Log in. It should be that simple.
