Arlo Delay in Asia?
  • 1 Reply
  • 3259 Views
atp2005
I am moving to Asia this summer and am curious if there are any Arlo servers in that part of the world. Also, I assume the Pro requires more bandwidth than the basic Arlo wireless, so if there is no server in Asia, it would be better to get the basic model to cut down on as much lag as possible, right? Any help would be greatly appreciated!
The Pro can peak at close to 1 Mbs.... so the min upload speed recommended by Netear is 1 Mbs
If the Netgear higher levels  are not supported in your area, normal internet above the listed speeds should work at the Basic service level
see; https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-available-Arlo-subscription-plans-...
If just starting out , I feel the Pro model would be the better option
Arlo Wire-Free Camera:
  • Best Video. 700-750 kilobits per second (kbps)
  • Optimized. 450-550 kbps
  • Best Battery Life. 300 kbps
