Arlo Camera not linked even with new batteries
I was having issues with a camera not turning on and saying low battery. I replaced the battery with a fully charged battery and it still said low battery. I thought the camera went bad but after several days with out it working I decided to remove the camera and re sync it. This fixed the issue. Hope this helps anyone that find themselves in the same situation.
Ryan
Sometimes after changing the battery , it will not show a gauge change... Most of the time a simple power button reboot of the base will correct this
