Arlo Base station is disconnected. Have 3 green LED lights I have done reset nothing works HELP!
  • 5769 Views
AAnd
it says my base station is disconnected.  i checked all the plugs I have 3 green led lights and even tried a factory reset and its still not working
AAnd
Yes I had to remove the device and add the device back again from my computer. It did not work from the app. This was after trying everything else recommended. Now it works fine
How did you do the factory reset?  If done by holding the reset button in for 10 secs , you would have had to resync the cameras too...
Usu if this is a problem AND is not the browser ( fixed by clearing the cache ) then it may help by taking offline your modem, router , and base unit and bring them back online in the same order...allow each to come online before the next
AAnd,
Adding to the comment above, if you have performed a factory reset on your base station (using the reset button) you would then need to remove the base station from Settings within your account and add the base station back using the "Add Device" button. After you have added the base station back to the account, you can proceed to syncing cameras.
AAnd
