Arlo Base Station won't work. Tried resetting. Amber lights will not flash.
Alro vase station (VMB4000)will not work. Have tried resetting, Amber lights will not flash no mater how long I press it. Have disconnected power, nothing. It goes through a cycle of light: power will turn green and then sync will turn green with power Amber. All light will go green for a sec, then back to only power light and steady Amber.
Hey Aakerna1,
If your Base Station power LED is showing amber, try to unplug your Base Station and wait for one minute to plug it back to see if that helps. You could also try reading this suggestion to see if this helps: The amber light won't turn to green on Arlo base station
Hi - have you resolved this? If not is it the same issue as this?
